Displayman
I am trying to remove the stock carb on our 47 Mercury
to clean it. We had old gas in tank that was ran thru carb.
I have replaced tank, fuel pump, sender. I want to throughly
clean carb.
I have removed the 2 bolts holding carb onto manifold.
Removed all linkage etc.
The carb will rock back and forth, but will not lift off.
I placed screw drivers under carb 4 places and tried prying it off.
I am afraid that I am going to break something.
Is there a trick to removing the carbs?
Is there something else that maybe still attached that I can't see?
My manual say to just remove the 2 bolts, then remove carb.
Thanks for any suggestions.
Bob- Hampshire, Illinois
clean carb.
