Cannot Feel l Light Switch Positions
Patrick
The model A that I just purchased has a aftermarket light switch.
When I move the light switch rod to the right to turn on the lights I cannot feel the spring loaded switch going into the indentations.The switch does work in all three positions,but I cannot tell at dusk if the lights are on without looking.
Could this be a very poor quality switch,or could it be missing some parts. There is good spring tension at the base when I put on the spider. Thanks
First is the bail all the way on and tight, then is it seated correctly in the steering column and all the way up, and lastly is it a REPO...because most of them SUCK and there is always problems, Check those things first, especially if the cap is ALL the way on the BASE.
Ah, I was wondering who snuck in and used my name.. I had a heck of a time getting a similar name to work..
Mt repo light switch didn't function when I first installed it. I put it into a lathe and made the neck shorter by about 3/8ths of an inch. Works fine now. Good contact and you can feel the detents.
Last year when I registered on the HAMB, I could not get Rowdy to work either, so I had to register under a different name. I looked under the members list and there was already 5 Rowdy's with slight variations. Decided to use my old e-bay sellers name instead. With the anticipated name claim game on opening day of the new barn I decided to get up early dispite working late the night before and make sure the same thing did not happen here. I was not sure how many Hambers would be now joining us or how quickly they would move in. Rod
I think it must be the cheap repro switch........ Where is the best source to get a good repro switch,or does someone have a good orig for sale.
Thanks
check the for sale area or get a hold of phoncon on ebay, that is Dan Bixby. i am sure he has an original. you will be amazed on how well it works and fits together.
