Can you help with this? Tool related
Russ/40
Can anyone tell me where to find the "mandrel" for this type roloc?
they were made by 3M years ago. maybe they are still available from them. I used to use them a lot with good results
I have acquired a large quantity of the older type, but have not been able to find a mandrel to be able to use them.
Google “3M Roloc Mandrel”. Came up with a lot of hits.
Back when I was still working, I bought them from industrial hardware store or aircraft supply houses.
Bob C, I think that is it. Apparently there are two or three sizes for diff size discs. Also, i don't see any way to back up the discs. Bob C's photo might be for that, but it doesn't look like it to me. RogerKB1936, what do you think of the ones in post #9. Is that the correct rear pad?
Bob and Russ..
That's what I use. I have 2 sizes, for the different size pads. I use 2" and 3",...the English
grinding flapper wheels work on them..
Dudley
Hi. Guys , yes the picture of the backing pads is right, I have been using them for years, they will thread right onto the threaded mandrel that is threaded into my Dotco angle grinder . I cut down one of the backing pads to 3/4" for those tight spots. Just cut the disc to about 1""The discs are available in several grits,and are good quality.Make sure you use safety glasses. Cheers
Source please?
Geez,....You live right down the street from S.D. There has to be an industrial
supply house the service's machine shops! You need to walk in with some of
pads so BOTH of you know what you have. I have both styles too attach the
different types of pads..
Dudley
The older style of disc had a 3tab attach to the adapter. The discs were known to come loose and zoom away ,very dangerous. If you still have the old style I would not use them .
