J jerrytocci Senior Member Jul 21, 2022 #1 My car is marking it's spot a bit more than it should. Should I re gasket the universal cover
Synchro909 Well-known member Jul 21, 2022 #2 There is a felt seal in each of the outer covers. It is not a big job to replace them and it's something often overlooked what a car is restored. The "spot" is most likely liquified grease from the universal joint.
Patrick L. Well-known member Jul 22, 2022 #3 There is no rear transmission seal. So oil leaks past and dilutes the u-joint grease as its designed to. So as said. the felts can start to leak and the ole 'A' will start to mark its territory.
