700rpm
What should be done about this? I found a 3/4" crack running from the top center of the water inlet on the side of the block, and about 3/8" into the water jacket. It isn't much more than a hairline. Can this be pinned on the outside and thereby stop the crack? Or is there a better way to stop or seal it? Or should I just ignore it? I've never seen a crack in this area before. What might have caused it? I don't see how it could be a freeze crack.
