So, I put a 5.5 head on my stock 1929 Model A 4 banger. Then I started to get some knocking - ok, I see people shaking their head yep. I assume the bottom end could not handle the higher compression. Correct me if I am wrong. But if that is the case, can I order a set of babbitts, or do they need to be "custom fit" - meaning I will need to pull the rods and have someone make babbitts to fit, then reinstall?
