Doing the brakes on my 28 Tudor, I got all new drums and two new hubs. When I went to install the rear hubs with new drums on the car, I realized that the race on the one old hub is BADLY worn. I do not believe that the race repair kits will fix the problem since there is a step between where the seal sits and where the bearing meets the race. I judge the wear to be almost 1/16". Question, is it possible to remove the new drum from the old hub and reuse it on the new hub? Or do I need to buy a new drum as well? Stupid me, I should have inspected the hub more closely before having a new drum swedged to it. Live and learn! Thanks in advance for your help.
