Here is a blurb that I answered to a similar question on the HAMB
First, inspect the top of all the leaves for grooving.
If grooved, grind and taper the tops of all the leaves for the last 3 inches. Bevel the bottoms up slightly also.
Just enough so there isn't a sharp edge rubbing the leaf below it.
The number of leaves you use will depend on the final weight of the car
and the "ride" you want. On a typical model A rod it is possible to get a
100 lb. per inch spring rate. Have the shocks disconnected when checking spring rates.
I parkerize the leaves before assembly. It makes the surface smoother and slows rust down.
I use 1/16 UHMW plastic between the leaves.This is the same as Teflon but about 1/3 the price.
After determining the final configuration of the spring I wrap it with black electrical tape
from the eyes to the U bolts. This keeps dirt out.
If you use a reversed eye main leaf, be sure the second leaf is short enough that there
is no way it can bottom on the eye when at full compression.
Sometimes the original spring clips will not reach over the spring after the UHMW is added.
It is a simple matter to fabricate ones that will.
The inside top of the cross member where the spring seats, usually has a radius.
BE SURE the top leaf of the spring has a radius to match. a sharp corner on the spring
leaf can cause a cracked cross member.
I use moly filled Delrin shackle bushings (home made) because they have almost no friction and they never wear out.
