Yes, but it isn't easy. Besides the obvious, radiator, front cover, etc. the valve springs must be removed which means the head has to come off, with the side door off the lifters must be raised and held in the up position, clothes pins will work here. The gear assy. that drives the oil pump and dizzy must be removed, then the cam can slide out. The gear must also be removed from the cam or the pan lowered to clear the gear.
