mantta
I have that annoying knock from the cam thrusting back and fourth when the engine is first started. After a few minutes of running it is no longer heard. I replaced the spring and plunger in the gear cover but it still does it. I have the aluminum gear and that makes it even louder. Would binding in the pump drivecause this? I even thought of modifying a timing gear cover, removing the plunger and spring and drilling and tapping the plunger hole and putting in an adjustable thrust screw. I read about this somewhere in this forum but can not locate it. Have any of you tried this? Thanks for any input you can give me.
