luvmyclassics
I was going to send my camshaft to Cam Techniques for a re-grind. When I called there today I was informed that they are closing. Any suggestions? I was hoping to get the L-100 grind.
I would ask Pete for a grind. He did several for me and they are nice.
Hi Pete, just to be clear, I'm not recommending copying at all, it just seems up here that there's a general consensus that the L-100 cam is a nice piece??
>It is that. So are at least 5 other similar grinds that various cam grinders
sell as whatever the customer wants but are so close in profile you can hardly tell the difference looking at the profiles on paper.
I have no reason to doubt it, but I've never tested one back-to-back with another brand. I can say with all honesty we can deliver a decent Flattie with the Isky line.
>As stated above, you would be surprised at how many different brands of cams (for a given performance spectrum) are almost identical.
I have stuck with Isky most of the time over the years. Mostly the 404.
Ed and I are good friends and he knows I am the only one doing 404 lifters now.
We've had no issues delivering 150/160 HP & 260/270# Torque on a basic stroker. Fairly straightforward for the most part.
We've been running low now on the original Johnson tappets which we purchased some years ago direct from Johnson. At that time we were below $4.00/per, how the times have changed. I don't have to tell you where they are now.
>That's one thing I have had no problem with. I have never built a flathead Ford using adjustable lifters. Even in the old days I used see a torn up cam once in awhile from a lifter coming loose.
We use to put 3 or 4 trays in at a clip, 96 to a tray back then I believe (92 now). I look back now and wish I had invested some more in them. But it's the same story with most Flathead parts, rods, mains, gaskets, etc. Back in the mid to late '80's and early '90's we were doing all the machining for one customer, he would be doing the assembling. He would average around 15 or so builds per year.
On a side note, this winter (if we slow down some) I'll be attempting to setup a hydraulic flat-tappet cam program. Will be "labor-intensive" but I have the plan in my head.
Thanks, Gary in N.Y.
P.S. The "nitriding" process on the cams I believe is a real "plus", but having said that, I can't recall the last "flat-lobe" I've encountered here, and we still do numerous flat-tappet platfoms. All mfr's, not only the Flatheads.
