Hello Bored&Stroked,
I believe you have hit the proverbial nail on the head perfectly. I do not see a hole in the end of the cam adapter where oil under pressure would limit metal to metal contact on the timing case cover and what you are describing makes perfect sense. Yes the mounting bolts did hit and grind away a section of the cast iron cover.
Your explanation of the related oil filtration system is also spot on.
And I concur, three main bearings and only two benefiting from a filter equals 66% filtration. This is why I was so upset over finding the amount of metal missing and knowing where it ended up, that the rest of the engine has little value or reliability without complete teardown, cleaning and evaluation.
Your explanation about the importance of and changes Ford made regarding to cam thrust is greatly appreciated and very helpful. My abilities to build an engine today have since passed and I will be leaning on professionals to do so as much as it pains me. I have done the majority of the other work on the car minus the overhauling of a rear end, the upholstery and paint. Frame off redo to create a daily driver for my wife and I.
I am contacting H&H on Monday to see what if anything they can do for this engine. If nothing is the result, then I will be making other tough decisions.
Thank you very much for detailing what I knew and saw but did not know why.
Sincerely and respectfully
Marc
Marc
