Ken Henry
I hesitate to start another camshaft thread but am really not sure how to proceed. I’m building a 276 ci 8BA engine to go in my 51 tudor sedan and find myself waffling about the camshaft. I’ll use a dual carb intake, EAB heads milled for a tight squish area over the piston, stock valves, and zephyr-type springs. The block will have some mild porting done. The car has an overdrive, 3.73 rear gears, and fully programmable fuel injection and ignition systems currently operating on a stock 239 ci engine.
My goal is to make the most power possible from the new 276 ci engine without degrading idle quality. I had originally planned to use a stock EAB camshaft, and have access to an NOS one, but am starting to wonder whether I’m leaving too much on the table with the stock cam? I’ve read ‘Flathead Facts’ and understand that any non-stock cam will sacrifice torque at typical ‘cruising-around’ RPMs, but it might be worth it for the added power at 3000 RPM and above. Plus low-end torque will still be way up compared to my current smaller engine with lower compression ratio, which seems to sign off pretty early with increasing RPM.
[FONT="]Any recommendations would be very welcome! Ken[/FONT]
81E4F735-C76B-400B-B889-208BFE47883C by kenhenry_06268, on Flickr
