cadillac512
The Zephyr springs are just a bit higher pressure...not much but they install same as stock and won't be hard on parts.
The rotators are just a different type retainer setup that allows the valve to turn slightly as it operates. The idea is to help reduce hot spots on the valve faces due to carbon buildup and to provide more even wear. That style was used on the last years of engines and uses a shorter spring than all earlier models.
Personally I don't think the rotator type have any advantage over the earlier type. They are not a positive rotation type like some modern OHV engines have used. Modern fuels have much less carbon buildup as well, lessening the need.
Terry
Terry
