Well the only thing I do well is make Chile ."Flathead Chile" And the recipe is in the book. Experience is the Key to success, and that comes from making allot of mistakes. Today I worked on a new designed disk brake system, got it finshed and it doesn't work, I made a mistake . Most of use old timers here offer some advice gained from these mistakes. However, Many mistakes go un noticed, and these are the real killers. One we're fixing right now is a rich condition on a 294ci engine that's running rich, It has 3 Stromburgs on it. 48 in the middle and two 97's on each end. Power output is fantastic. But cruise AF is rich and this is bad news for rings. Leaning out the 48, gives poor preformance at low speed/ Put 1 1/4" risers under all carbs and this improved the low speed response. re jeting the PV of the 48 makes it stumble in low revs. The biggest problem is. IT RUNS JUST FINE FO I LEAVE IT ALONE. wANDERS ALL VER TOWN WITH NO PROBLMS. wILL GO OVER 70MPH BEFOR THE SECONDAIRIES KICK IN. sORRY ABOUT THE CAPS. jUST INSTALLED A 4BL ON IT.
This is a learning experience, The 4bl is just temporary, Just want to see how the engine preforms in cruise, need the AF up around 15 + for good Mileage
Gramps
