Kurt in NJ
I was looking through my cam pile trying to select a cam for next build and peeled some of the cosmoline off the love of what I thought was a NOS stock cam, the lobe tip is more rounded than a stock cam, so I measured it, the base circle is about 1.125, the lobe lift is about .326, which is more than the original used cams, even the base circle is larger by a little so it isn't a re grind most likely, there are no markings on either end other than a seemingly random stamped "J" next to dist drive slot
I know that to have all the specs I would have to clean it off and degree it with dial indicator but was hoping someone would know it by the look and lift
