Cam ground pistons
Dave72dt
I know current production pistons are cam ground to compesate for heat distortion. Were they always cam ground or originally true round ground? If so, when did that occur?
Not all manufacturers used cam ground pistons. It wasn't until the advent of aluminum in piston manufacture that cam grinding became routine. In Cushman engines the cam ground pistons didn't appear until the early 50's. Of course these were air cooled engines and had more radical temperature variations than a liquid cooled automotive engine.
I have a Van Norman piston grinder which I'm sure is from the 1940's, that will grind them either way. I think that is the time frame (40's) when it became common.
