cam gear nut
Al Bass
what is the best way to stop the cam from turning while tightening the cam nut ? cam is installed in the engine. I have a fiber gear and i'm afraid of breaking teeth (on the gear) if I hold it by stopping the crank from turning
I have always been told to remove the starter motor and place a block of wood between the flywheel ring gear and the flywheel housing. This way the gear can be removed unharmed.
I like the rag method the best. If you use a locked crankshaft to hold the cam gear, all that pressure is on one tooth of a fiber gear.
Put a rag between the teeth, put the transmission in high, block the wheels so it does not move, and apply force gradually with breaker bar and a camshaft nut removal tool. I have used the cold chisel method, dont recommend it.
What method would you use on an aluminum gear, engine not in the car, flywheel not on engine ? How many foot pounds torque ?
I do it different than most. I take the side cover off then put a strong clamp on the gear then it will not hurt the teeth.
ive used the correct cam nut wrench with no luck . i use a chisel with the end ground flat , so as not to cut , & lock tite (red) . seems to work good for me ....... steve
I ended up putting a 2x4 between the block and crank and made a practice tightening with the old cam gear with no broken teeth so I put the new gear back on and snugged up to 100lbs . I feel better now.
the engine is out of car on engine stand going back together
