denson1932
on the front surface of the block behind the big cam gear there are 2 little
cuts (grooves) in the thrust surface i assume for oil to lube this thrust surface..should the front cam bearing therefore be driven back a small amount to allow oil to feed to these grooves? ...1936LB....
