rockfla
SO when checking a wire for continuity, IF the wire is "grounded" somewhere along its entire run, will it still read "continuous/continuity"? OR will the fact of it being grounded interrupt continuity??
Follow up question to above.......IF it shows continuity EVEN IF it is grounded THEN what would be the best way to test IF the wire is grounded (or shorting)???
Thanks
Thanks
