Cadillac 331 in a Ford
Hey Mike, add a picture of your blue Coe for an avatar. Then create some albums in your User CP "photos and albums" and upload pictures of some of your big iron. I am sure guys here would love to see your 39 too.
Thanks to all that replied!
I am looking for the front bearing retainer for a Cadillac Laselle transmission. Also hub
that holds throw out bearing and clutch arm. Any leads appreciated.
My former 39 Ford Coupe had a 331 Cadillac backed by a 1937 LaSalle floor shift 3 speed transmission. Here is a picture of the motor mounts in place. Sorry - do not recall what manufacture they were.
There is a fellow on H.A.M.B. that Cad stick trans is all he does. Search there - Cad Lasalle Newc
A friend of mine did this '39 coupe and I will say, he did a good job. No shortcuts...
Classified Ads - 1979 and Older Cars For Sale - 1939 Ford Deluxe Coupe - Classic Cars & Trucks For Sale - Northwest Classic Auto Mall (nwcam.com)
I do not enter very often. I bought a pair for a Cad install in my 26 Ford coupe. If I remember correctly I looked under Hot Rod or Ra$ Rod Cadillac engine mounts. Very seldom
do you find a Hurst set. Good luck
That looks like it was a real beauty!
A few pictures of my former Cadillac/LaSalle 1939 Coupe -
[FONT=&quot]
[/FONT]
[FONT=&quot]Powered by a 1951 Cadillac 331 ci bored to 365cu backed by a 1937 LaSalle 3 speed top loader floor shift.
1951 Cadillac Engine
365 cu in (bored from 331ci)
4" JE forged pistons
Stock Crank and rods
Eldorado dual quad intake - WCFB Carter carburetors
Eldorado big port heads
Eldorado exhaust manifolds
Eldorado "Batwing" Chrome intake air cleaner
Chrome Cadillac valve covers
Nielson Vintage Racing Cam - 432 lift/282 duration
2" dual exhausts
275hp/344 ft lbs at the rear wheels - dyno reports included
11" Weber Clutch
Front Suspension - 4" dropped front axle (NOS Cragar)
Rear Suspension -- 2 " drop - Chassis Engineering rear suspension
Chassis
Chassis Engineering parallel rear springs
9" Ford 3:50 rear plus traction bars
Custom open driveshaft with front yoke slip joint
5.5 bolt pattern wheels all around
.5.5" front - 1950 Mercury
6" Rear - 1950 Lincoln
41 Lincoln Front Brakes[/FONT]
[FONT=&quot]
[/FONT]
2" dual exhausts
11" Weber Clutch
Chassis
538832
538835
538837
538833
Just sent my early 51 and 52 Cadillac distributors to Charles Schwindler in New York. He is going to modify/update them with later fly weights and vacuum advance to use manifold vacuum. I will try to post some photos when I get them back.
Did you find your bell housing to do the install ? Years ago I bought one believing it would fit my '52 engine , but it may be for the later engine that you have . I'm still looking for an early style adapter . Maybe we could trade ?
When I was first on the H.A.M.B., I saw a link to "Belmont's" site. At that time, they had the entire Offenhauser catalog on it. Turned out that it was just for reference only, but it drove me crazy for a while, because just about any Internet search for old speed equipment ended up there. They had none of the old stuff.
I haven't been led that far astray since a certain stripper back in '92.:D
What is the H.A.M.B.? I have seen a reference to it several times, but I am clueless.
The Hokey *** Message Board
https://www.jalopyjournal.com/forum/forums/the-hokey-***-message-board.5/
