I have a 1930 Cabriolet and I need the small escutcheon that goes on the top end of the landau iron between the top material and the landau iron. Need both sides and I don't see them at the usual part stores. Any suggestions on a source would be appreciated.
Call berts
Steve should know if they are available
1 800 321 1931
I see Joop posted A&L info. I think they are more irregular in
shop of late. I hear Alan is not there full time and some personnel retired.
Hard to find anyone these days that can/will meet the requirements and needs for a small run production shop.
As an update. A&L does not have this part. I purchased the escutcheon for the window crank for a later cabriolet. It fits quite well. I ground off the little tabs that would normally press into the upholstery. It stands off the top by about 1/8" so you can see some black. I think if I reshaped the rubber seal a bit it would fit perfect.
