c69a rebuilt
i tap some treads in the fitting ,and used a brass bolt,which i bored a 1/16 hole in it. i but 680 loctite on treads and tighten up my adapter with a flat screw driver. i think that should work! its the smallest drill bit i had.
Making one is fairly easy, there are also turbo oil restricter fittings you can get. An original fitting may be difficult to find.
