I have a 56 Merc with a 302/C-4. Originally I did a 289 early C-4 swap, then picked up a low mile 302/C-4, swapped it in, and went thru the "oops it shifts backwards" thing with it, solved that, wore out the 302 and was getting ready to pull it for rebuild. I had a 401 Buick nailhead that a friend wanted, and he had just picked up an F-1 pickup project that came with a fresh 302/fresh C-4 and tradedit to me for the nailhead. Well, it is in, running and driving. It shifted like the early C-4 so I again reversed the linkage. Someone had banged the tail housing and it was ovaled where the seal goes in and an ear was broken off of the mount. I changed out the tail housing with my old one. That made for two vents in the ******, but ****** guy said it wouldn't hurt as long as there was a vent. Also, this new ****** doesn't look like it comes apart at the bellhousing (no seam, but looks like it would have the bolts inside the housing) As the engine block had been smoothed out and everything was done real clean, I suppose the seam could have been filled for clean looks before painting.
My problem is that I can drive it no problem, but after being driven 40 or 50 miles and parked it leaks fluid. It has to set for a while before it leaks, and it leaks considerable amount of fluid. Enough to run out from under the car, and I don't mean trickle out from under it. There is no sign of fluid anywhere on the underside of the car, so I don't think it is leaking while driving it. I can't see anywhere that it is running down or dripping out of the ******. I do not know if the dipstick is the correct one, but it is the one that came with the unit to me. The end is broken off of the dipstick. The top end that is curled. Could I not have a C-4, or the wrong dipstick? Fluid is not coming out of the top of the tube, (or at least the tube is dry) and is not coming out around the bottom. Sure got me and my son stumped.
Sorry, I got it in the wrong forum I think.
