C-4 Auto
F.M.G.
Ok guys I am tired of shifting,clutch chatter, I now have a 3 speed 1950 trans. I have a C-4 core that needs a rebuild, where do i get a adapter for a 1950 8ba? It has a stamped steel bellhousing, and is still 6 volt. The kits I find look like they fit the block that has part of a bellhousing on the back of the block. Thanks, Mike
Flatomatic makes a kit to fit your engine.I have one behind a 50 merc. engine in my 32 hi boy,it works great and was simple to install. Phil
I also have the Flat-o-matic (out of Oregon), in my '40 with an 8BA, easy to install, works fine.
I have one of the Flat-O-Matic kits in my Tbird behind the YBlock. Everything fit and worked.
