The 20 ton press will push those bushing out with no sweat. What I did not realize when I did the job, is that original Ford script sector shaft bushings from 1940 were still good, with no slop in them. I checked them with a telescoping hole gauge after I pressed them out, and the ID was very close to 1.125, the sector shaft OD. The "40 has about 42K on it. So, you may want to check those bushing before you replace them, like I should have done,
