rfitzpatrick
What is the rated horse-power of a stock built Burtz? What other Chassie modifications should be considered?
Thanks
Thanks
the bearing area is about equal i figure, building oil pressure takes some power,
The head,cam lifters,valves pistons and all external parts the same
exactly the same cam timing
I suspect it would be about the same , with the variable of being at minimum clearance versus maximum clearance , balance at optimal numbers or at opposite limits
I would say that if you build up a Burtz engine with some mods above factory (hotter cam, higher compression head) that with your 3.54 rear end you should definitely be able to increase your top speed. More so if you added in an overdrive. At least that's what I'm counting on to justify my Burtz/Mitchell build!Yall are really a help -- I thank you.
Now -- I've never driven my '31 PicUp over 45. I get the impression that with the Burtz, I could do more. My 'up-grades': F-1 Ford Steering Box. A 3:54 differential gear. New Radiator. Now would say a speed of 60 be within reason, plz?
TKS
TKS
my coupe that is stock except for a B cam easily goes over 60, was clocked by a state trooper at 62 and that wasn’t flat out— I was asked if it was stock, the troops wanted to see under the hood— grungy original look ,obviously stock, he just shook his head and told me to keep the speed down.
I didn’t tell him it would go almost 70
stock 3:78 rear, have driven it all day at 65 in the past
I smiled to myself and left him scratching his head.
I can't believe you guys drive one this speed. I did hit 45 once and lived to tell about it!
