The hole in cam bushings 1 and 4 needs to be small if you are using an original 5-bearing camshaft because the oil distribution groove goes completely across the camshaft journal and vents to the crankcase. Whenever the groove aligns with the feed hole, there is a drop in oil pressure and the gears in a mechanical oil pressure gauge will wear. If you are using our new 5-bearing camshaft, the oil distribution grooves do not extend to the ends of the journals, and the hole can be larger. The small feed hole works with original 5-bearing camshafts and the new camshaft.
