Good Luck! And post updates..!Hello. Current engine in Model A Is getting tired, rods have no more shims to pull, so finally started to work on the Burtz been in crate for a couple years,please wish me luck.!
Be aware that ANY "machine work" will void the warranty. Ed Tolman is building Burtz engines. The head gasket failed on the one in his car. Here is a video of him machining the head to correct the surface. On all his new builds he surfaces the deck and head to assure they are flat.If you can, machine a little off the top of the bosses where the cam followers go. That makes it so much easier to adjust the valves.
Have ordered a Burtz cam and valves for engine, still trying to decide the cam followers , single lock or double, might go with single due to larger base .Just cleaning and de burring so far.
This is from the Burtz engine assembly manual.
We recommend that "single lock" Colony CM102-8 tappets be used for flathead applications. For OHV applications where the adjustment is at the rocker arms, stock Model A or Model B tappets can be used.
B lifters have a larger diameter base than A lifters, a good thing on a performance cam.
The B lifter is also 0.032 inch taller or longer.
