I fouind the info,its a bit hard to read but they used AISI 1020 steel with.125 wall.
Lawrie
Since I shared that message with Lawrie, I've made another handful of '33-34 type driveshafts. This setup has worked well behind a sbc (spiritedly driven too) for 10,000 miles.
I start with an original '33-34 Ford front coupler, or have used '35-36 front couplers as well. The back end gets turned down for a 0.002" interference fit into a new tube.
For the rear coupler, I start with a new 6-10 spline coupler from VanPelt. The diameter gets turned down to 1.750", which allows the use of a torque tube seal from Danny Burroughs at Bruce's Rod Shop (a great piece for lowered cars). The tube end of the coupler gets turned down for a 0.002" interference fit into a new tube as well. Another thing I do is "cap" the tube end of the coupler. This prevents any oil from migrating through the splines (again, on a lowered car) and entering the hollow tube.
Now for the tube....In my message to Lawrie, I had used some plain DOM mild steel for that project. It has served well with no issue. Since then, I've moved over to using 4130 chromoly seamless tubing only because I can more readily get the material (often times from Aircraft Spruce).
I've found most original tubes are 0.095", but I've occasionally seen slightly heavier wall thickness. I've been using 0.120" wall, only to increase the bending stiffness of the driveshaft.
I use my lathe, when the length permits, to weld the shafts in an effort to keep them as true as possible. I have a local machine shop that has the capability of balancing these shafts, so I take every one I make to them. I'm sure it's overkill, but for $70, it's worth the added peace of mind.
