Bud Sub-rails
I have just compared a Budd cab and a regular 30/31 cab and apart from the steel top they appear identical ,even the seat riser looks the same . This is by eye but if you wish I can get a tape and measure if you advise me where . What difference in the seat riser do you see ??? .The entire lower body looks the same to me .
John in sunny morning but even more rain on the way Suffolk County England .
I no longer have either of those in the shop but have before.
By memory, the steel crossmember at the front of the seat is wider. Also, the seat riser is a bit different
Can't help with actual measuring
The regular side rails can be modified.
