Bubba 34 Condenser
Steve Staysko
Bubba i wish you would build and sell the Vertex Mag "lifetime" condenser modified to fit a 34 helmet distributor please I'm tired of replacing faulty condensers. If you build it they will come and I will be the first to order one! :)
I believe Bubba did post a photo of an original style condenser modified so the mag condenser would fit inside the case. Also possible to solder the ground strap to the rear of the mag condenser case. Both modifications use a screw and nut to attach the wire end to the coil. Check this link:
https://www.fordbarn.com/forum/showthread.php?t=250123
I did just that a few days ago for a 36 I am working on. Simple enough and even on a concourse vehicle, it is impossible to detect.
Not a problem just send me the condensor you want done up ( as there are some variations) and we can get it done.........
