glenn in camino
Is a metal timing gear worth the money in a stock engine? I put a bronze one in my last rebuild for durability but now I can hear it at idle.
I had to use my bearing plate and 20 ton press on at least one to remove the gear.
Glenn - Trying to use my common sense (I know that's a stretch for me), but most A'ers will concede that the fiber gear will be less noisy than a metal (bronze in your case) gear. There are others with such metal gears that are not noisy (Why? - I do't know). I do know that there is a person (maybe someone can supply the name, I don't remember) that manufacturers matching metal gears (crank & timing) that said by users of such to be quiet. But it makes sense that metal will out-live the fiber gear (all things being equal).
Saying a metal gear is worth the money is subjective (after all we are human). To me there would be satisfaction knowing the metal gear will be durable. Others opinions may differ. Then again, could I live with the noise?
Would packing the timing gear case with grease make a difference in the sound?
Whew,,,,,,,,,,,,,,,,,,,,,,,,a 4 year old thread.The timing gear ghost.
