Roxo
I discovered this by removing the valve cover to do a inspection. The only thing that came to my attention was #8 valve stem was kicked out of center on the tappet, away from the block by maybe 1/8". With my thumb I pushed it back into place. I could feel it pop into place. It was in the down position at this time.
both before and after I had turned the engine over by hand to verify all valves were moving up and down.
After replacing the head (Head was cracked) and putting things back together she started right up. But this time I had a tapping noise. So I opened back up and took out that valve. Here is what I found.
So now I guess my question is what is the best way to fix this one valve as the others seem to be just fine. My compression was in the mid to upper sixties when checked. Should I just replace the two piece guide?
Valve stem is not bent. No nicks or scratches.
