lafarm
Had a post a few days ago about a broken piston, I installed four new pistons and rings re shimmed everything had the manifold re surfaced and got it together goes down the road real good at 45/50 mph but has very bad slow idle I think it has an intake leak somewhere can close the idle screw in the carb all the way no difference open it 1/2 turn makes it worse, I removed the manifold checked gasket replaced no change put a little oil around intake ports while running no change vacuum windshield wiper works good trying to figure what do next?? Gordy
