Broken Model A Fan Blade with car damage
Re: Danger - Original Model A Fan Blade
Google "fan blade failure", it is common ,even on quite new cars the fans are breaking ---also some articles of porosity in cast alum fans causing failure --the dangerous fan that causes death and injury is the flex fan of the 70s, 80s, a proven killer---but no recall or ban on them.
The hood does a good job of containing a fan failure --standing in line with the fan with the hood open and reving up the engine was a common denominator in all the deaths and injurys I found in online searches.
There are a lot of bad original fans, there are also good original fans ---the argument that they are going to fail is valid, everything will eventually fail in use ---the aluminum replacement will fail ---some have already failed, the taper has wallowed out, machining defects, pulleys split off--- some due to misuse and improper installation ---this has also caused failure of original fans
All fans are dangerous ----except perhaps the rubber bladed vacuum defroster fan.
The Snyders aluminum fan would be far more reliable... especially if you just use an over the counter fan from the auto parts. Usually those last about 2-4 years.
I an getting one from Mattsons Radiator to go with the new 11 fin per inch radiator.
I'm going to make a fan out of an old mower blade! They never break! I've hit things that would have taken out a Mod A fan in an instant and the blades were only nicked a little. I jes got to find a way to create the pitch.
Terry
Terry
Good luck on that! :D
I recently hit the city water valve cap and bent the 28" blade on my Bolens mower. No one has a blade, so I bought a 28" Snapper blade on ebay, and had to drill 2 holes to make it fit my Bolens. I got 1/8" before dulling my centering bit. I could't find any bits that would touch it, so I took it to my friend's house the other day and he used his vertical mill with a 3/8" end mill to make the holes. It got the job done, but wrecked the end mill. My Bolens blade was only bent about 3/16", so I clamped 2 pieces of angle iron on the ends to stand the blade on edge, then hit the center with a sledge hammer. It didn't budge at all.:mad:
See what I mean, Tom! You smacked the blade with probably 4-6 HP and it only moved 3/16! Try that with a Ford fan! For drilling very hard materials, I had an toolmaker show me something. Take an old center drill and grind a little negative rake oon the tip. It sounds crazy i know, But sometimes it will get you through. Run it very slow with "Tap Magic". I once was making destruction test samples/bars and they had to have center holes for cylindrical grinding. It was a high temp, super exotic, Titanium, tantalum, columbium and God knows what else, alloy. Nothing would touch it! I recalled this trick and it worked. It's kinda spooky when a center drill will only polish a little spot on the work. Of course. there's plenty of heat treated steel that nothing will touch, no matter what, if the Rockwell is too high.
I straightened some blades for a neighbor by clamping them to the big bucket on my Case backhoe and getting about a 6 ft pipe over them. I had to flatten the pipe somewhat to do it. But they were a lot straighter than when he brought them to me.
Terry
