sonny30coupe
I have a newly rebuilt engine ready for the car. I also happen to have an engine test stand that is set up with radiator and the works. My question is, is it really a good idea to run that engine on the stand before it is put in the car after the resto, or should the engine have the forces at work against it that it gets when being ran in the car. Shouldnt it be ran with the pull on the motor and all or is good to let it just "freewheel" on the stand with no drag on the motor? I hear of guys on here all the time running engines on test stands but not sure if it is a wise idea to do so. I would like to hear it run before it gets installed in the freshly painted newly restored car just in case there is a problem and it would need to be removed. Your thoughts please. Thanks in advance, Sonny
