james hitchcock
That fan looks as if the blades have been twisted to give them a little more pitch. A little scary
I also thought the fan didn't look right, but would like to see a closer picture of the hub.
Has the fan been shortened?
As long as the filter is of proper size to flow the CFM of the engine there will be no performance reduction. It is simple mathematics. A = (C.I.D. x RPM) / 25,500. You can go a step further and be sure of no restriction by using a Hiboy that has the K&N.
Just because Henry didn't think it needed a filter doesn't mean it shouldn't have one.
Teflon tape will cause more problems than it will ever solve. If you put a klittle too much, you can crack fittings or what they screw into. When you remove the fitting particals of the tape will enter the carburetor and cause problems. I don't even like teflon tape for plumbing use. If I used any type of sealer it would be something like Permatex high tack. Brattons lists this product on page 37 part number 7840. This sealer is usually available at any parts store that sells Permatex products .The gas line fittings on the carb and sediment bowl use ferules and really should need no sealer . The cut off valve and fittings under the tank may benefit from the use of this type sealer, especially the cut off valve . Be sure to use the stand up filter that fits in the cut off valve and stands up in the bottom of the tank .
The vacuum line is definitely not the correct one. Two questions: Is it leaking? Are you going to enter the car in fine point judging? If the answer to both of the questions is no, I would probably just leave the line on the car and not worry about it.
