Brass Ford script
dirt t
How do you mount the script to the radiator? Snyder's says use fine wire?
Thank you for your time.
Terry
Here is a picture of one on a T
I copied a script that had 3 small holes as shown. I used some screws throuhg the radiator but the fan come awfully close to the nuts. Brass wire might work better.
It's fiddley because the fan is in the way but brass wire works well. Not too tight and be sure to go around the tubes. You'll damage or pull out the fins if you use them only. There is a screw kit offered but like 15max says their close to the fan.
Any idea where I can get a screw kit.
Thanks
Terry
