Brakes
TMarsh
Have 4000 miles on my coupe with no brake adjustment since everything rebuilt by me. Originally had 3/4 pedal travel, now have about one half pedal. Stops good and straight, cast iron drums, no overheat. Should I adjust them now are just keep on driving until the pedal gets lower?
Try adjusting the wedges in one or two clicks all around and see how that works. If the car pulls to one side afterward, back that side (usually the front) off one click or tighten the other side one click. 'Costs nothing and takes all of one minute to do all four backing plates. Brakes shoes wear from use and it's up to you to make adjustments to compensate for that.
Marshall
Once the brakes are adjusted correctly and the car stops without pulling to one side, regular maintenance is just to adjust each brake the same amount. Start with one click all around. If that is not enough, add one more click. Make sure the adjustments settle into the clicked position correctly and not between clicks.
4,000 miles is perfect timing for adjusting your set of completely rebuilt brakes.
The two posts above cover it all. Follow them.
Enjoy.
Yes, "nkaminar" brings up a good point. It's possible when adjusting the brake wedges to land on a high spot on the wedge instead of in one its grooves. That will often either lock the brake shoe against the drum or give a false setting as being too tight. When you think you have reached the point where fairly heavy resistance is felt when test spinning the wheel, wiggle the adjusting wrench back and forth to ensure the brake shoe adjusting shaft's tip is resting in one of the wedge's grooves. You might surprised to find afterwards that you can adjust even tighter.
Marshall
The first adjustment tends to come a bit sooner no matter how excelent the brake job is. I guess the shoe material needs to season a bit.
