Thinking about doing front disc brakes on my 37. Anyone recommend a kit? I have read most make the track width wider but can`t find info on how much. Any advice would be appreciated.
Tommy .....IF you're still in the "Thinking About It" stage concerning the use of disc brakes, can we ask
WHY?
I'm guessing that the short answer to that is going to be ...."Because my vehicle doesn't stop as well as I would like". Fair answer!! Can we assume that your Cabriolet probably has '40 through '48 Ford hydraulic drum brakes on the front? If so, yup....it could surely stop better than it does now. But DISC BRAKES?
Yup, we've all heard that disc brakes stop a car much better than drums. We need go no farther than our current DAILY drivers to qualify that idea. In fact, SOME sporty cars like Camaros will flat make a believer out of you....they STOP! But, understand that there is a whole lot more to an efficient and effective disc brake SYSTEM than just magically bolting-on an adapted Camaro rotor and caliper. Sure, the ads make it sound easy, making one think that all of the adaptive hydraulic fittings can be sourced to making the hook-up to your existing master cylinder a walk in the park. You finish bolting those parts on, bleed the system, go for a test drive, and chances are that you're going to be very, VERY disappointed. You're likely going to have to STAND ON (push extremely hard) the pedal for the brakes to be effective at all. This is because of a list of probable factors that MOST disc systems have engineered into the package.
You must remember that disc brake calipers usually require more pressure to work properly than drum brake wheel cylinders do. And, unlike modern-day Bendix-type brakes, your disc brakes do NOT have a "SELF-ENERGIZING" feature by the very nature of their design. And ya know what .....the stock old Ford Lockheed brakes on the front of your car right now don't employ that feature, either. One thing you forget about is that MOST disc brake systems employ a power brake booster. Those really help you PUSH that brake pedal for some of that much-needed effort to make discs STOP you. One more really important factor when it comes to upgrading with discs is the proper sizing and properly matching of master cylinder bore DIAMETERS with the caliper bore diameters. Master cylinder bores generally have to reduce in diameter to afford the pressure increase required for discs. On top of that, reduced master cylinder bore diameters MAY require an increase in the BRAKE PEDAL STROKE length....does your pedal mounting afford the room for additional stroke length, if necessary? There is a lot more to making a disc system WORK as expected than just bolting-on the discs and calipers.
So, what do ya do? The really smart thing to do this past few years is like what
"19Fordy" did above (as well as many others here on The 'Barn have done). Get your hands on a set of the reproduction Lincoln/Bendix "self-energizing" brakes that will absolutely bolt-on to your front end with only a few minutes grinding required on the top portion of each spindle. These Bendix-type brakes on front work very well in conjunction with the stock old Ford Lockheed brakes on the rear. Rears actually do much less to stop a vehicle than fronts.
The Bowling Brothers supply beautifully engineered and manufactured components for fronts & rears if you so desire. They have the ONLY replacement brake drums for 1940 & '41 Ford front hubs that are worth bringing home. And beware....Speedway offers look-alike drums that have had many problems with out-of-roundness and out of balance. Stick with the REAL Boling Bros. drums, also referred to as MT Car Products....they are the SAME folks! And on these old Fords, they STOP! Check the extensive web site below. And for what it's worth, Gary ("Krylon32") is a Boling Bros dealer, and offers a 10% discount to Ford Barn members. You don't really want DISC brakes in front. See link BELOW! DD
https://www.bolingbrothers.com/front-brake-kit-for-1937-1948-spindles/
