...but i will not get back to the problem until the weather is better around here, heat and humidity's got me out for the count.
Hi Hope ,(this may not be your problem but ) My suggestion to use a air gun comes from working on a car with the MC low in the floor much like 39 Ford ,I just could not get a pedal It felt like trapped air we had bench bleed it so I knew it worked ok ,in my absence the owner had the MC re kitted after replacing it we experienced the same problem so out of frustration put the 40 1lb air into it and bingo got a full pedal .You would think this would mix air with it but it doesn't.
