Remember, you have an Emergency Brake and if you 'hold the top button down' as you pull back on the lever, you should be able to stop the car over distance.
[FONT="]
[/FONT]
[FONT="]As another reply noted, If at all possible, THE BEST THING is to get the advice of experience from someone near you. Try and find someone/group near you to help you and make new friends at the same time.[/FONT]
[FONT="] [/FONT]
[FONT="]I would advise that at the very least you acquire a good Model A Shop Manual and/or a service manual if you do this yourself. There is a spec. for a 2x4 wood block cut-out that I found on this forum long ago. Some may still have that info.
[/FONT]
[FONT="]
[/FONT]
[FONT="]ALL of the following is predicated on the understanding that your linkage is tight and adjusted evenly and correctly, especially the 15 degree front angle to start and as you say your shoes are relatively new.
[/FONT]
[FONT="]
[/FONT]
[FONT="]'NOTE' - as a 'hard' rule the brake pedal should ALWAYS be no less than four (4) inches from the floorboard when the brake pedal is fully engaged and quickly pressed to come to a full stop.
[/FONT]
[FONT="] [/FONT]
[FONT="]In any event, here is advice on one way to adjust your brakes - takes two people[/FONT]
[FONT="]A quick way is to first, jack up the front of the car (both wheels suspended and spin free). While the Model A has lots of ground clearance it is always advised to use jack stands as well.
[/FONT]
[FONT="]
[/FONT]
[FONT="]Begin to spin one of the front wheels as you turn the 1/2 square adjustment bolt 'clockwise' one click at a time (found on the inside back-plate). Once you hear/see/feel the brake engage and slow the wheel, turn it back one or two clicks - these are actually notches you can feel with your wrench.[/FONT]
[FONT="]
[/FONT]
[FONT="]Next, go to the other front wheel and do the same thing (again, use jack stands). Then spin both front wheels at about the same speed and have someone firmly press the brake pedal and see if the two wheels slow and stop at the same time.
[/FONT]
[FONT="]
[/FONT]
[FONT="] If so, then take the car for a short test drive (in an empty parking lot) and holding the steering wheel slightly, push firmly on the brakes to see if the car pulls to one side or the other. If it does, adjust the opposite side (clockwise a click or two) and repeat the drive until correct.[/FONT]
[FONT="]
[/FONT]
[FONT="]Then do the same for the rear wheels. The rear wheel brakes should generally engage directly after the front brakes. If you have calibrated the front brakes correctly, this can be checked by jacking up one side (front and back) and spinning the wheels and then having someone firmly press the brake pedal as you observe the braking of the wheels
[/FONT]
[FONT="]
[/FONT]
[FONT="]Adjusting the Emergency brakes is a process involving the linkage.[/FONT]
