In Don Montgomery's excellent picture filled hot rod books you can spot many a pr-1940 model A with the splash aprons still on even though the removed the fenders. This was a necssity when mechanicals were installed to keep the rods from getting damaged plus they looked kind of funky hanging out there.
Kerby
My first thought would be if you had an accident a smart lawyer would ask why you increased the horsepower and didn't upgrade the braking system to match (and it would probably be a legitimate question).
Charlie Stephens
Defending mechanical brakes Henry said, "The safety of steel from pedal to wheel".
Charlie Stephens
An equally smart defense lawyer would then point out that horsepower is a moot point, as you don't step on the accelerator and brake at the same time, so the HP is essentially zero regardless of the engine while braking.
Check out the Flathead Ted brake energizer kit for Ford Mechanicals. Makes them self-energizing like the shoes in Bendix type hydraulic brakes. Here's a link to the video:
0)"]http://www.youtube.com/v/2EjRe411l3M
