With hydraulic brake systems that have an adjustable proportioning valve between the front and the rear, it is always stressed for safety reasons to adjust the valve so that the front brakes begin to grab just before the rear ones. Can't think of any reason why mechanical brakes should be done any different.
Randy,
The proportioning valve does NOT cause the front brakes to come on first. It ONLY controls the total pressure that can be applied to the REAR brakes, so they don't lock up & come, "*** AROUND" Chief "ASSED AROUND" 3 times, in his '62 Ford short bed P.U. & later, added a proportioning valve, problem solved. Before the valves were available, he carried 2 bags of sand in the rear of the box, to prevent lock-up & SCREEEEEEEEEECHING!---Bill W.
Sorry if I offended you, Randy, Buddy, The DogNot quite sure exactly what your point is Bill, but it seems you've taken what I said out of context somehow.
The following is a direct quote from the installation instructions of a Summit Racing adjustable proportioning valve:
"Front-to-rear brake balance should be adjusted so that the front wheels lockup slightly before the rear wheels".
Other than my use of "grab" where they used "lockup" did we not say the same thing??
