Brake voodoo?
36tudordeluxe
Interesting. When adjusting 40 Ford brakes the same suggestion is made - applying 25-30 pds. pressure to the brake pedal. See second photo below.
Two different things maybe as I cant open the link. The instructions posted would push the cylinder ends out, then the anchor ends are adjusted.
I get "The file you were looking for could not be found" when trying to look at link.
I would guess that the board holding the pedal down is forcing air out of the lines and cylinders some how. ?
I would arrange a reservoir to ensure the master does not run out.
Not that I'm a good sleeper anyhow.
I am trying to get my head around why this would work. Where could the air go? I know that "gravity bleeding" works quite well where the master cylinder is higher than the rest of the system, but unless this car has been converted to swing pedals, that's not the case here.
One question for the O/P; are you using DOT-5 brake fluid? If so, perhaps the pressure is causing the brake fluid to absorb the air in the system.
I can't see the link either.
Hi 19Fordy,
These instructions you have are to push the shoes out temporarily for anchoir pin adjustment only. The 2X4 overnight trick gets rid of air bubbles in the system. I've mentioned this a few times on this forum based on success for me., most recently here, https://www.fordbarn.com/forum/showpost.php?p=1815347&postcount=3.
I started doing this for my motorcycles after seeing it mentioned in bike forums.
Try it, it works!
even in a pressurized system, the air will rise to the top and out the reservoir. I'm guessing this is what is recommended for the final bit of air. That's my best guess.
Here is the correct link.....
https://forum.wscc.co.uk/forum/topic/65562-wedging-brake-pedal-down-overnight/
It's called latent (hidden) air in the system..... the only place it could go in a brake system under continual pressure would be out the master cylinder seals (or calipers/wheel cylinder seals). This assumes an un-compromised hydraulic system with no fluid leaks.
Beats me if this "2 by 4" method works though. Never heard of it before.....
