... Similarly, if the hub is excessively worn then it needs to be sleeved (I’ve seen hubs worn through the surface treatment), if the hub is worn there are repair kits that you can get from the vendors (https://www.snydersantiqueauto.com/product.htm?pid=976171&cat=41720) that have a sleeve and a smaller corresponding bearing.
