Brake System for 40
40fordpu
Have a 40 truck. Does anyone know the stock location of the brake line? Does any one have a picture? I assume it is no different than a 40 car. Run the fronts from the master to the driver side across the front cross member under the engine. The backs are run from the master along the x member above the drive shaft and "v's" to each wheel? Any help is greatly appreciated. Thanks
I can send you clear and detailed photos of a correct (actual) install.
Send me your email address in a private message and I'll get them to you promptly
