I have a new brake switch for a 36 ford with mechanical brakes.
Is the switch set up with normally open or closed contacts before moving its stem (rod) in ?
I tested the switch with a ohm meter with connections at the 2 wire terminals and without moving the switch stem the contacts appear to be closed showing a closed circuit. As I move the stem in a good ways it shows a open contact.
This seems to be the opposite of how I think it should work ?
I would think pushing the brake switch stem plunger in by stepping on the brake pedal would close the circuit and the brake tail light would come on.
Haven't installed the switch as I would like to be sure it functions properly on the work test bench first.
