modelacarman
What is the Best brake lining to use with cast-iron drums? The woven tape or soft molded type?
FWIW
I did a brake job a number of years ago on my 1931 S/W Town Sedan 160B and was not able to get any effective braking. I had new cast iron drums trued, and bonded lining on used shoes arched to the drum. After much time and frustration I learned that the brake shop that did the lining on my old shoes used hard bonded lining. The shoes were glazed and did not engage the cast iron drum.
I believe that hard bonded lining is for hydraulic brakes where you have increased force to engage the hard bonded lining to the brake drum.
I then did a brake job on my 1931 Cabriolet 68B and used cast iron drums with soft bonded lining on used shoes arched to the drum. I spent a lot of time getting the shoes centered; eventually I made my own brake shoe roller pins with a different head diameter for each pin that would center each shoe.
I later learned that in the 50's brake shops were bending the shoe to fit the arc of the drum. When you bend the shoe you change the distance from the center line of the upper hole for the brake adjusting shaft pins and lower hole for the brake shoe roller pins. This affects the ability to center the brake shoe.
I then went back to the brakes on my 1931 160B and as it had cast iron drums I used soft molded lining on new shoes arched to the drum and the result was fantastic!! The shoes were basically centered.
I will never do a brake job unless the shoes are new, with soft molded lining arched to the drum and cast iron drums!!!
Below is the Raybestos KAM Way shoe arching tool
What do you think contributed most to the better brakes,
soft linings
Putting the brakes together correctly
both
I question how many shoes have been changed in diameter. I am not doubting it can be done, but I have a pile of them. I asked a person to check the factory diameter at the archives. I then made a template on a piece of aluminum plate. All the 30 or so shoes I have were spot on with the arc. So selection went to the shoes with the tightest holes at the ends for the pins.
The molded lining used in late production and post production were of a softer material. It is also a different color. It is not the grey/ black you see, but more of a brown.
